what fuel pump?
Old Aug 15, 2001 | 02:25 PM
v8power's Avatar
what fuel pump?
As I am in the middle of my Carb 2 TPI swap
I was wondering if any one could suggest an external fuel pump I could use so I dont have to drop out my fuel tank
I want to hook it up by the fuel tank hopefully one that will thread into the stock fuel filter and just suck right off the original sending unit
I am replacing the fuel lines form the tank to engine
Objects in mirror are more stable than they appear
www.members.home.com/v8power
4BBL to TPI in the works
86 350 5spd
E.E.T (Electronics Engineering Technologist)
Old Aug 15, 2001 | 08:54 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
<font face="Verdana, Arial" size="2">I want to hook it up by the fuel tank hopefully one that will thread into the stock fuel filter and just suck right off the original sending unit</font>
i'm not 100% sure but won't you have to take out the old pump anyways? won't it restrict the flow?
someone that knows for sure please post.
Andrew
[This message has been edited by smokin87iroc (edited August 15, 2001).]
Old Aug 15, 2001 | 09:36 PM
v8power's Avatar
there is no pump it is carburated right now
i dont want to pull the tank out if I dont have to I do have the sending unit with the electric pump out of the same car the tpi came out of
i would rather save the time and get an external one
Old Aug 16, 2001 | 12:09 PM
Car: 87 IROC
Transmission: 5spd
sorry i wasn't thinking.
i'm not sure on a external fuel pump cuz i'm still using the stock one.
someone has to know though.
if not just look in jegs and stuff and find one that can put out the higher psi required for fuel injection
Andrew
Old Aug 16, 2001 | 12:28 PM
hotpowerandperf's Avatar
Use external pump from 88-89 ford truck with 302 FI. This is master part number E2000.
John
Heart of Texas Power and Performance
Old Aug 21, 2001 | 09:34 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
I'm no expert, but I think you'll have to drop the tank anyway. Carbed engines dont have a fuel return line like fuel injected engines do. You have a couple of options:
1. Drop the tank, install an in-tank EFI fuel pump that include the fuel return line.
2. Drop the tank, add a fuel return line to the top of it next to the rest of the fuel lines, and use an external pump.
I am certainly no expert at this, but that is just what comes to mind. Hope this helps.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
