TPI+Direct Port Nitrous...
It was a toss up on where I should put this, but I'm sick of trying to make up my mind on whether to go miniram, superram, yada yada...so I was just thinking, how about a nice direct port system... has this been done, and what's about the most you can run with it as far as power? I know the 500 shot is out of the question, 300 maybe???
Car: Take
Engine: Your
Transmission: Pick
To see a TPI Camaro w/ Direct Port Nitrous, check out Rick Linstedt's car: Rick's car
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
[This message has been edited by GMTech (edited August 17, 2001).]
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
How about a LT1 intake converted for my tpi car with direct port under the intake
Links.
http://albums.photopoint.com/j/View?...nce=0&res=high
And
Jerry
Sorry you have to copy and paste them.
[This message has been edited by JERRYWHO (edited August 17, 2001).]
[This message has been edited by JERRYWHO (edited August 21, 2001).]
Links.
And
Jerry
