New Injectors
Old Aug 17, 2001 | 12:15 PM
88 IROC BOB's Avatar
New Injectors
I am going to be swapping in a set of new Accel 23 lb injectors soon. Is there any tips or things I should watch out for?
Thanks,
Bob
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Old Aug 17, 2001 | 03:08 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I think if you swap out the injectors you have to get a custom chip. I could be wrong, but that is what I was told when I was considering it. Instead, I just took my stock ones out and at this very minute they are at Cruzin Performance getting blueprinted.
Old Aug 17, 2001 | 03:33 PM
rezinn's Avatar
You don't need a custom chip, there isn't much of a difference between 22# and 23#. Make sure you replace every o-ring in the fuel rail that you touch, or it could leak. Lube the o-rings up with oil, use the injector clips, good luck.
Old Aug 17, 2001 | 06:47 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Transmission: TH700-R4
Do you think you need a custom chip with 24# injectors?
91 Camaro Z/28 5.7
SLP catback
SLP runners
SLP 1 5/8" headers
TPIS airfoil
160 degree thermostat
Rebuilt 700R4(borg warner/raybestos clutches,Kevlar band,vette servo)
B&M 2400 stall torque converter
Old Aug 17, 2001 | 07:40 PM
irocbsa's Avatar
You could always use a custom chip. Even on tatally stock engines. Just look at what Glenn has done with his L98. Is it absolutely necessary? No. Would a custom burned chip be highly beneficial? YES.
vsa
Old Aug 18, 2001 | 04:34 PM
VetteMan's Avatar
Changing your fuel tables to match your new injectors is the right thing to do. Get with a tuner in your area and see the difference
V/R,
Frank
Tuner
Old Aug 19, 2001 | 01:38 AM
91'firebrd's Avatar
Your computer will compensate at part throttle but WOT settings could make it a little rich. I swapped to 24 lb SVO's and increased the pressure to 49lbs and did not change the chip and had no problems.
Old Aug 19, 2001 | 11:18 AM
Just out of curiosity, what is the "shop time" for doing this? I can usually double what it takes a "real" mechanic to do it.
Bob
Old Aug 21, 2001 | 05:31 PM
irocbsa's Avatar
Swapping injectors??? I can have mine out, still attached to the rails, in about an hour. Add 30 mins in there to pull them from the rails if the clips are being a bitch.
bsa
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
