Fuel pressure setting.... HELP!!!
Old Aug 21, 2001 | 04:25 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
I am reading on the boards that the stock setting is around 46 PSI. I have an Adjustable Fuel pressure regulator on my L98 and I just installed an Accel fuel pressure gauge. It is reading 35 PSI!!! That means I have been driving around for the last two years with 35 PSI.
I was only able to turn it up to 37PSI. It seems pretty difficult to change, because the distributor wires, etc are in the way. What is an easy way to quickly change the pressure? What PSI should I probably be running (approx) with the mods that I have?
Any help/comments/info will be greatly appreciated.
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech chip with 160stat, Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, !TB Coolant, Spohn Dual Cat SubFrame Connectors, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's
1989 Chevrolet Celebrity Eurosport
2.8 MPFI, no mods
225,000 miles and still ticking!
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
Old Aug 21, 2001 | 06:33 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
I don't know what it is, but nobody EVER replies to my posts.
I really need an answer on this. PLEASE help me out.
Old Aug 21, 2001 | 08:08 PM
R.O.B.'s Avatar
Ballpark, I'd say you want to be around 45psi. But I'm not familiar with aftermarket pressure regulators, sorry.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
48psi regulator, (Nickel method)
Old Aug 21, 2001 | 08:45 PM
Z28DJP1987's Avatar
I asked a question a few days back about FP
at idle and was informed by Vader that it was
37 +/- 3psi. Check some the earlier posts on setting FP. For your info my FP at idle is 36
psi and set at 41 psi for wot. Just had car dyno and this was optimal setting for me.
Old Aug 21, 2001 | 08:48 PM
86Z28TPI's Avatar
Are you checking the PSI with the vaccuum line off it? If not you should be. Disconnect the vaccuum line and plug it with your finger and then check the pressure. If you leave the vaccuum line on you get a false reading.
Old Aug 21, 2001 | 11:27 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Yeah, i have been checking it with the vacuum hose on and guess that i was wrong in that. Where exactly is this vacuum hose so i can disconnect it next time.
Thanks,
J.R.
2.8 MPFI, no mods
Old Aug 22, 2001 | 09:12 AM
custman87T/A's Avatar
Follow the FPR to the plenum and you cant miss it its the only vac. line running to the FPR.
87 Black on Black T/A
T-Tops Digital dash
5.0 TPI S/R Torquer 305 heads Summit TPI cam
204/214 @.050 .420/.442
SLP headers and catback
A4 with 3.42 gears
Fully loaded and everything usually works.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
