TPI Fast burn 385
Car: 91 Formula
Engine: 5.0 tpi slow
Transmission: WC t-5
TPI Fast burn 385
I am looking at buying a fast burn 385 crate motor to replace the tiresd 305 in my 91 formula . I would be using an accell super ram and SLP Tri-y headers and the obvious computer mods to go along with this motor, does anyone have any other suggestions that would be better off for me running this motor? Not sure how well those headers will work on this motor, or if that intake is any good on this motor? any suggestion /advice is greatly appreciated. thanks
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: TPI Fast burn 385
You'll need the Vortec TPI intake from Scoggin Dickey. And I would recommend Dyno Don's 1 3/4" headers.
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
i bet the hp rating of that crate engine will cost alot of money to acheive with what your attempting.
Car: 91 Formula
Tanks for the input. not sure which way I'm gonna go, kiinda why i'm lookin for advice/suggestions. I was also lookin at a zz383 whith the Accell intake , like I said though, I'm not really sure on what I wanna do. I have a couple small blocks already, And also have a 400SBC, But I was kinda leaning twords a Crate motor, simply because I don't have the time to put anything together, and I kinda just want to one already complete
thanks
thanks
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
build that 400sbc with afr heads. hello 500hp. can u afford to efi your engine?
that stock tpi stuff and crate engines dont mix at all. thats alot of buying stuff. 750dp looks very good 2 me.
Iroc8t8
May 4, 2026 08:09 PM
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
