Looking for a tech article for MAF to SD conversion.
Old Aug 21, 2001 | 01:36 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I am thinking about going to SD, since everyone says it works better with a modded engine.
Anyone know if an article that shows what needs to be done and what parts are needed to do the swap.
Thanks,
WS6 Trans Am.
View My Ride @ thirdgen.org
Old Aug 21, 2001 | 05:48 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Here ya go, this is the site I based my MAF to MAP conversion on. It works very well.
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
How's that carb to TPI swap going I was helping you with?
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Aug 22, 2001 | 05:34 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Thanks John, I was sending him over to
www.sethirdgen.org
to talk with you or Bernard. The MAF to SD experts!
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Aug 22, 2001 | 07:01 AM
IH8FORD's Avatar
As many times as this question is asked why doesn't this site post a tech article on it?
[This message has been edited by IH8FORD (edited August 22, 2001).]
Old Aug 22, 2001 | 02:16 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
It's one of the hundred or so projects on
my plate to do. I asked the moderator a
while back just to link to my page from
the Tech Article Section but it never
happened..
(I also have a circuit board mask done to
do the conversion with no wiring, making
adaptors, etc., but it's sitting on the
pile also..)
mike
My Z28, ZZ4swap, TPI EPROMs
Old Aug 25, 2001 | 06:23 AM
Zepher's Avatar
<font face="Verdana, Arial" size="2">Originally posted by John Millican:
</font>
Thanks John,
The swap is going pretty good.
I am just waiting on a couple of items for the car, 52mm TB, 2 1/4" Wheel Adaptors, etc... just small things.
I have a couple of other questions, but I'll save them for later.
Thanks again,
apie2546
Oct 16, 2016 02:24 PM
jaridjohn
Oct 5, 2015 07:01 AM
racereese
Oct 3, 2015 03:46 PM
