Intake install question (i LOVE winter :P)
Old Mar 11, 2008 | 11:51 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
Hi again,
Its a winter wonderland up here in northern NY, and i have a question regarding the installation of my newly ported edelbrock intake/runners. due to the cold and my outdoor workspace, will i have any issues swapping my intake? will i have any seal/gasket issues? i am trying to get her back up and running by the end of this month, and it seems like the winter is lasting an eternity. my concern is that if i apply the correct torque to the bolts now while the metal is cold.... will i then have an over torqued condition when the block and intake expand with the heat? i don't wish to crack/warp/damage my new parts, or have vacuum leak issues when i fire her back up... so any advice would be greatly appreciated.
thanks, you all rock
Jason
Old Mar 12, 2008 | 01:33 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Intake install question (i LOVE winter :P)
No issues, reassemble
Just dont fire it up for a day or two to let the sealant setup
Old Mar 12, 2008 | 09:32 AM
thunder85's Avatar
Engine: 5.7L w/hsr
excellent. thank you very much
Old Mar 12, 2008 | 01:24 PM
billydonn's Avatar
Car: 66 c-10 stepside
Transmission: TKO 600
It may be obvious but, keep your sealants inside and warm until you are ready for them.
Old Mar 12, 2008 | 02:28 PM
thunder85's Avatar
Engine: 5.7L w/hsr
gotcha... thats kind of a last minute thing anyhow... i will keep the intake warm untill the block and heads are prepped and ready too. is there an rtv type that i should be using in this case? obviously the sensor safe stuff, but should i use black, blue, red?
another question, gasket related: edelbrock has that gasgacinch intake gasket goop they recommend be used when installing an intake gasket. what is that crap actually (generic name of the substance), and is that something i can get a generic brand of at napa or autozone?
Old Mar 12, 2008 | 02:39 PM
Pocket's Avatar
Car: 91 Trans Am
Just use the old style RTV
Its worked fine for decades
Light bead on both sides of the gaskets and a heavy bead on the china walls
Lay the intake down strait and dont wiggle it around trying to find the holes, if you miss, pull it back up and reapply the sealant especially around the water jackets
Let the bolts to the squishing
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Fast355
Dec 2, 2016 06:33 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
