89 Iroc Conv-stalling
Old Aug 26, 2001 | 02:29 PM
Sheavy1991's Avatar
305 TPI, stalls with no warning mainly on low rpm such as stopping or idling or right after start-up. Has stalled at highway speed and trying to pass someone. Sometimes will keep running if you drive with 2 feet to up the rpm. Weather plays no factor, hot or cold motor plays no factor. Idle rpm is around 550. Replaced computer twice, MAF, O2 sensor, injectors, battery, cleaned throttle body, checked fuel pressure, vacuum leaks, ignition coil, replaced key ignition tumbler. Still has problem. It will stall for 3 - 4 days and then will be fine for a week. Has been at mechanics for the last 3 weeks. Computer has no codes in it. Tried to take it to the Woodward cruise and it was disasterous. Stalled constantly when I hit the bridge to the US. So it now sits at the mechanics with everyone dumbfounded. Anyone have any ideas before I leave a lit cigarette in the thing. Cannot sell it the way it is operating.
Old Aug 26, 2001 | 04:37 PM
mckenzie's Avatar
when it stalls, will it start back up? might want to put a fuel pressure gauge with a long hose on it, tape the gauge to the windshild and see if you have fuel pressure when veh. stalls. maybe your fuel pump is going out? need more info. best of luck, tom
86 iroc 305tpi auto. mild cam
Old Aug 26, 2001 | 04:46 PM
Sheavy1991's Avatar
Car always starts back up but may stall immediately again. If you drive with both feet you can usually keep the thing going.
Old Aug 26, 2001 | 07:36 PM
jmon92conv's Avatar
I have battled the same thing. Mine was the fuel pump and the sending unit was cracked and leaking air. If it is the sending unit, get one at a junkyard, the new ones hurt the pocket book.
Good Luck
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC, 3.42's, Edelbrock STB, 350 in the works
Old Aug 26, 2001 | 07:39 PM
Sheavy1991's Avatar
would you not be able to if is the fuel pump by doing a fuel pressure check? My pressure test was fine.
Old Aug 27, 2001 | 09:06 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Somethinge else to consider......
Check ALL of your grounds. One on the back of each head, one under the dash on the drivers side in particular. My car had a similar problem, would just quit, right out of the blue. Seems one of the bolts for the ground on the back side of the passenger head (the one that is the hardest to get to.....) had worked it's way loose. Hit a little bump, or step on the gas too hard, and it would break the circuit, and the car would die.
Just a thought.....
Good luck
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
