tpi
Old Mar 14, 2008 | 08:10 AM
ohhyea89iroc's Avatar
tpi
where does the sensor on the bottom of the plenum hook up
will the tpi run without the egr stuff?
Old Mar 15, 2008 | 07:54 PM
ironleg's Avatar
Car: 1988 iroc z28
Engine: 357ci
Transmission: 4sp auto
Axle/Gears: stock for now
Re: tpi
from what i know yes the car will run but you might need to reprogram it and im not sure what you are asking about the plug under the plentom
Old Mar 15, 2008 | 08:07 PM
BAD88IROC's Avatar
Car: 88 IROC-Z , 00 CAMARO SS
Engine: BUILT 5.7 IN THE IROC, STOCK LS1 IN THE SS
Transmission: 700R4 , 4L60E
Re: tpi
I think you are talking about the intake air temp sensor kinda on the back and bottom of the plenum. should be a 2 wire plug i beleive
Old Mar 16, 2008 | 10:08 PM
Re: tpi
yea thats the plug. where does it plug in at and what would cause poping and not running.i put on a tpi setup and now the engine does not want to run. i know its got spark and fuel but what eles would cause it not to run. help plz!
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
