Why the blocked rear intake coolant ports?
Old Aug 28, 2001 | 12:31 PM
89vette's Avatar
Why are the rear coolant ports on TPI engines blocked? Is it better to use regular gaskets with open water passages? Seems to me that it would be better to be open.
Jason
Old Aug 28, 2001 | 04:39 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Thats the way pretty much all SBCs came from the factory. Open gaskets won't do you any good if there isn't a coolant passage in the manifold. I haven't looked at a TPI manifold to see if it has them, i know most 87-later TBI/carb intakes actually did have a rear coolant crossover.
I don't know that having a rear crossover really helps anything with regards to cooling. Like i said, most SBCs that rolled off the line came w/ them blocked, and likewise, most aftermarket manifolds also have them blocked.
1992 Trans Am
May 10, 2023 07:19 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Fast355
Dec 2, 2016 06:33 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Jake_92RS
Aug 11, 2015 10:39 AM
