smog pump removal
Old Aug 28, 2001 | 04:07 PM
88TAJeff's Avatar
Car: 88 T/A
smog pump removal
Ok, while doing the recent cam swap, I had to un-hook the air cond. of course, so I decided to scrap the A/C. The compressor is still there until I can get a replacement pulley. Can I also get rid of the smog pump? will this have any adverse effects on driveability, etc? I plan on getting headers later on and don't want those damn air tubes on there.
Thanks.
88 Trans Am 305 Auto Red/Silver, MSD coil,wires, ported plenum, gutted airbox, TB bypass, comp cams 08-408-8, everything else stock
Old Aug 28, 2001 | 04:21 PM
Drakar's Avatar
No driving problems on if you have smog check that you might get it on a visual, or in the sniff you might but if no smog check then go for it, Dyno results lower down show a 3hp gain on smog belt alone.
1989 Trans Am GTA, 5.7L TPI, TH700-R4, T-Tops, dual cats, 9-bolt rear, 3.27, Dynomax muffler, K&N
1992 Camaro RS, 5.0L TBI, T-5, T-Tops, 3.08, L69 Dual Snorkel, K&N - Sold
Theme song for my GTA Cake - The Distance
Old Aug 28, 2001 | 05:06 PM
88TAJeff's Avatar
Car: 88 T/A
Thanks- no smog check in my area
RazorN8
Jan 7, 2022 11:44 AM
italiano67
Dec 11, 2016 09:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
