Question about TPS
Old Aug 27, 2001 | 07:58 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Question about TPS
With the engine running is the TPS voltage supposed to remain constant or does it fluctuate?
Earlier I was out resetting the IAC and TPS, I forgot to remove the probes from the TPS when I started the car and noticed the tps voltage was all over the place, anywhere from .30 volts to 1.90 volts
Is this normal? The car does idle a little rough, not really bad, but enough to be annoying.
Thanks, John
89 Formula, Maui Blue,355 TPI(used to be TBI) Auto, TES, B&M shift kit, afpr.
Old Aug 27, 2001 | 08:28 PM
Guest
Guest
Posts: n/a
Nope thats not right if the throttle isnt moving. It should stay within about .01 or so depending on the quality of your meter.
Old Aug 28, 2001 | 05:37 PM
Thanks Max.
Heres a little more info, if it helps.
I did some more checking today, I've got good ground, alt output is a steady 14 volts.
With engine not running the 5 volt reference from the ecm is 4.9 volts, but with the engine running I'm getting anywhere from 9 to 13 volts on the reference wire it fluctuates quite quickly. Is this normal? Do I need to replace the ecm?
Would somebody be willing to check thier tps voltage with the engine running so I can compare it to something?
Thanks again.
mdtoren
Aug 23, 2015 12:52 PM
BurlyChev
Aug 22, 2015 11:42 AM
redmaroz
Aug 16, 2015 11:40 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
