stealth ram, heads, and cam....set up?
Old Mar 15, 2008 | 09:08 AM
sweet_87_iroc's Avatar
Car: 1987 Iroc-z camaro
Engine: 5.7 Liter
I am thinking about buying a stealth ram setup for my 87 350 TPI. I need some suggestions on what is the best set up for the stealth ram when it comes to heads and a cam? Thanks for your help!
Old Mar 15, 2008 | 06:57 PM
BAD88IROC's Avatar
Car: 88 IROC-Z , 00 CAMARO SS
Engine: BUILT 5.7 IN THE IROC, STOCK LS1 IN THE SS
Transmission: 700R4 , 4L60E
Re: stealth ram, heads, and cam....set up?
If you are looking for great power for a fairly low cost i would go with the Vortec heads. You can get them used for a few hundred bucks or less and get them machined for a higher lift cam and big springs and you will have a great set of heads. As far as a cam i would go with a comp roller somewhere between .500 and .520 lift would be a good combo with those heads and with the vortec stealth ram intake. Thats pretty much the setup i am putting together now. should be good.
Has anybody used the stock tpi fuel rails with the stealth ram intake??Have to modify anything to make it work??
9192camaro
16
Feb 3, 2019 12:21 AM
92projectcamaro
Jan 18, 2016 08:00 AM
Mutillator
Sep 17, 2015 04:38 PM
z28guy134
Sep 1, 2015 11:50 PM
L98GTA87
Aug 11, 2015 06:55 PM
