What is this part ?
Old Aug 27, 2001 | 11:45 AM
88TAJeff's Avatar
Car: 88 T/A
What is this part ?
When you take the cap off the distributor and look just under the rotor... this brown circular thing about 1-1/2 to 2" in dia- sort of like a collar around the rotor shaft. Anyway, is it normal for this thing to move? mine moves about 1/2" clockwise/ CCW. thanks
Old Aug 27, 2001 | 11:14 PM
88TAJeff's Avatar
Car: 88 T/A
Anyone???
Old Aug 28, 2001 | 12:09 AM
makinemtap's Avatar
Ignition module maybe...hell, i am a rookie, i might be totally off, but mine didnt move, it was held in place with two small screws
Old Aug 28, 2001 | 12:45 AM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Your pick up coil resides under there. If your car has been feeling a little doggy lately it is remarkable how much of a difference replacing this part will make
91GTA 5.7liter needs paint, I rebuilt the trans, engine is moded but old
Old Aug 28, 2001 | 09:13 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I think you're referring to the reluctor, but it should be secured and not moving.
IIRC there is two screws holding it down.
Old Aug 28, 2001 | 10:23 PM
espirocz's Avatar
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
Inside the dist. there is a brown shield that covers 4 poles, inside those four poles there is a magnetic wheel that creates a signal that the computer reads to determine engine speed to map fuel by. If you look close and see cracking in the magnet you will want to replace the main shaft in the dist. The pickup coil is under the mag wheel on the main shaft. My 5.7TPI w/slp headers to flomaster had a bad backfire under decell after rolling off the gas at higher rpms. Sounded so bad it embarassed me to do it, it also had idle instablity (read: ROUGH). Replacing the mainshaft, had to buy whole shaft because the magnetic pick up wheel is pressed on it from G.M., and the pick up coil it Ran better, it ran stronger, and now has no back fire. Throttle response improved too. NOTE : When pulling Dist. make sure you make or make good visual note where the rotor points before pulling up on dist. and once Dist. gear comes free from cam. Also get new seal for dist housing to block.
I'm done talking. Good Luck.
Old Aug 28, 2001 | 10:27 PM
espirocz's Avatar
One more thing dont forget to mark Dist housing to block so the timing willbe close enough to start and then set BASE TIMEING back to run good setting (factory or otherwise.)
See YA!
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
