few early/late MAF TPI interchangability questions...
Old Aug 29, 2001 | 10:33 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Ok, here's the deal...I got a 1986 wiring harness in my IROC. I'm buying a whole new system. I bought some good used SLP runners for the '89+ systems w/o the cold start injector. No problem there. I'm about to buy a 58mm TB and a Edelbrock TPI base...should I buy the early TB or late TB? My plenum is a ported '86 unit. Which should I buy, or does it matter? As far as the base goes, I'm assuming I should buy the early unit, since I plan on keeping EGR and will probably use TFS 23* aluminum heads. The main concern is which TB I should use since I no longer have coldstart, early or late with an '86 plenum?
Old Aug 29, 2001 | 10:39 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You'll need the early style TB for the '86 plenum.
Old Aug 29, 2001 | 10:43 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Also, the TB has nothing to do with the CS injector, that's in the runners only.
Differences in the TB's are where the IAC passages are, maybe something else, don't recall and it's too late to go out in the shop and compare spare parts
The base should match the head, some manufactures will work for both early and later style heads though.
Old Aug 30, 2001 | 02:19 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
The later tb's IAC air is entered into the two main bores, where the earlier ones went through the triangular hole between them.
Old Aug 30, 2001 | 07:22 AM
dhirocz's Avatar
cool...so I'll get the earlier TB!
89GTAOz
May 16, 2020 09:31 AM
NBrehm
Aug 25, 2015 11:49 PM
trevor1010
Aug 24, 2015 11:29 AM
Bert87
Aug 23, 2015 03:50 PM
Sanjay
Aug 12, 2015 03:41 PM
