is there a way to make 88TPI intake work on 86-below heads
Old Aug 28, 2001 | 11:31 PM
RED82TA5.7L's Avatar
Car: 96 Formula/82 T/A
Engine: LT1/350 TPI
Transmission: T56/TH350
i got a 1988 TPI setup for my 82 T/A. but the heads are 86-below version..is there anyway to make an 88 TPI intake work on 86-below heads? is there a place that drills them out? or am i going to have to buy a 86-below intake
thanks
RED82TA5.7L
1982 Pontiac Trans Am
Cross-Fire Injected 5.7l V8
New TH350 Raptor with a shift-kit, 2600 stall torque converter, Eldebrock TES Headers, 3" Hooker Cat-Back.
Mods: 1.6 Proform Roller Rockers, electric fan, Corvette 5.7L computer chip, K&Ns, MSD 6A Ignition Box, MSD Conductor Spark Plug Wires .
Audio: JVC Kameleon CD deck, Jenson 4x6 front, Eclipes 6x9 rear, 2 10" mTx T4000 powered by a mTx 200watt amp.
Black Powder Coated 1990 16x8 Formula Wheels with 245/50/ZR16 Perelli P7000, 1.5" Jamex Lowering springs(pics are before lowering springs, ill get new ones soon).
For Pictures go to
http://www.geocities.com/red82ta57l/mycarpics.html
A cool Trans Am site with Message Boards http://www.transamgta.com
Old Aug 28, 2001 | 11:44 PM
bicknese's Avatar
Well, I'm a newbie at this but I believe the only difference is the angle the holes are drilled between older and 87 and up. If you are feeling confident you can just elongate the holes enough to make it fit. I'm not from the area so I couldn't tell you if anyone could do it for you. Just my two cents. Good luck.
Old Aug 29, 2001 | 02:33 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Yep, a die grinder with an aluminum cutter works good to change the angle in the intake. Some thread sealer on the bolt and a little silicone in the unused area seals it ok.
Old Aug 30, 2001 | 06:39 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I've got an 86 Intake base that I am selling, make me a reasonable offer and It's yours.
WS6 Trans Am.
View My Ride @ thirdgen.org
Old Aug 30, 2001 | 07:25 PM
90Form350's Avatar
Like everyone said you can elongate the bolt holes. Thats what my friend did in his 86 TA that was accepting a 1990 L98.
1990 Pontiac Formula 350
Rebuilt 355
COMPCAMS 212/212 .440/.440 cam
Flowmasters 80 series.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
NBrehm
Aug 25, 2015 11:49 PM
89mulletbird
Aug 12, 2015 07:08 PM
