VSS Difference?????
Car: Death Mobile
Engine: 666 c.i.
One is optical and the other magnetic. The SD 7730 ECM has a "switch" that allows you to run the older style VSS.
Get into EPROM Burning and you can easily make this change. Burn proms, don't buy parts when you don't have to.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
[QUOTE]Originally posted by Glenn91L98GTA:
[B]One is optical and the other magnetic. The SD 7730 ECM has a "switch" that allows you to run the older style VSS.
Glenn: Can you tell me where to find that switch in the tables?
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
'92 CAMARO RS
B4C Alt.
Numbah-1
Sep 12, 2015 08:57 PM
