serpintine belt size
Old Mar 20, 2008 | 08:29 PM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
I did the search so please no blasting, I have just got a complete under drive pulley system, and my belt is routed for the NON-smog pump now.
But you have to have a shorter belt since the size of the crank is so much smaller....like 1 3/4 inches, the tensioner can not make that up, plus the tensioner would hit the water pump pulley.
does anyone know the length I would need...
or would I be safe to get one that is about 1 3/4 smaller than 96.8 I have now?
any help would be great
thanks
Old Mar 20, 2008 | 08:46 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: serpintine belt size
sounds to me like you already know what you need.
I would say yes to the 1 3/4" shorter belt.
Sorry,don't have a part number for ya.
Old Mar 20, 2008 | 10:38 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Get a tap measure. (Fabric one) and route it the same as a belt. Then figure in the tentioner. Or just buy a crapload from the part store and return what you dont use!
Old Mar 21, 2008 | 10:26 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
thanks
Why don't you get the smog pump delete pulley?
You can still use the same belt and it doesn't look like something's missing in the front of the engine.....IMHO.
Nervous2
Oct 8, 2015 10:53 PM
scottmoyer
Sep 20, 2015 11:54 AM
iroczguy86
Sep 13, 2015 02:22 PM
m00n420
Sep 11, 2015 02:39 PM
MORREALE5
Sep 10, 2015 08:58 AM
