TPI Porting
Old Sep 4, 2001 | 05:08 PM
90Form350's Avatar
TPI Porting
Hey guys, I have a few questions about porting the stock TPI. First, if I siamese the two bores on the plenum that the TB bolts up to(or make them bigger at least), would there be any gain? I already flattened out the walls behind them. Also, how about siamesing or enlarging the outlet holes of the plenum, and then knife-edging the runners and base? The car its for has a small cam and 24 lb injectors, but nothing else (Friend's car). Any thing other suggestions?
1990 Pontiac Formula 350
Rebuilt 355
COMPCAMS 212/212 .440/.440 cam
Flowmasters 80 series.
Old Sep 5, 2001 | 01:54 AM
FlashGTA
Guest
Posts: n/a
From the sound of it no, it won't help, you'ave already done what needs to be done. The base is the real plug after that the runners. And of course don't forget the log exhaust manifolds.
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Sanjay
Aug 12, 2015 03:41 PM
mx127
Aug 10, 2015 08:13 AM
