Any pics of the TB bypass?
Old Sep 2, 2001 | 08:44 PM
DFI79MC's Avatar
Car: 79 Monte Carlo
Engine: 406
Transmission: 2004-R
Axle/Gears: Phord 9 inch/3.90
Does anyone have pics of it done? I did mine, but I'm curious where I should run my heater hose to now. Where did all of you guys run your hose to? I know I have seen enough sigs that say they have it done, so where did you all put it? Any response will be greatly appreciated. Thanks
[This message has been edited by TPI79MC (edited September 02, 2001).]
Old Sep 2, 2001 | 09:00 PM
85 T/A WS6's Avatar
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
I would like to see the same also and would like to ask this question:
Why cant you install a small gate valve in line to the TPI ???
You can open it in winter and close it it summer if needed.
Would this cause a problem or does the coolant need to circulate through to cool something else ?
This mod might be done on my car, I have read that up to a 7 hp gain is expected, also I have seen that it makes little difference.
Hmmm....
Don
58,000 miles
5.0 TPI
WS6 (.92g)
3:27 Posi
Hi Flow MAF
K&N
[This message has been edited by 85 T/A WS6 (edited September 02, 2001).]
Old Sep 3, 2001 | 12:45 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
I just bought a new section of heater hose and ran it from the block to the heater core. This got rid of the short piece from the block to the TB, which was rotted on my car.
Simple, easy, and likely the hoses need replacing anyway.
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Old Sep 4, 2001 | 08:55 AM
90Form350's Avatar
You can't install a valve because the cooland usually flows from the heater core through the TB and into the intake to continue circulation.
1990 Pontiac Formula 350
Rebuilt 355
COMPCAMS 212/212 .440/.440 cam
Flowmasters 80 series.
Old Sep 5, 2001 | 05:20 PM
redhottlb9's Avatar
if you're willign to go through the trouble of installing a valve,why not just re-install hosing in factory spots when colder months come around???...just a thought...
as far as where to run the hose...
[i]you got 4 points,one on the driver's side of the TB (1) going to one on the intake (2),
then you have one going from the heater control valve (3) to the passenger's side of the TB (4)..all you gotta do is run a length of hose from the intake port (2) to the heater control valve (3)...[i]
if i had pics id post them,but its really not hard at all...
i did mine in 5 minutes,and i did BLADE's and FLY89GTA's in about 15 combined...
drop me an email if you need further help/advice
Andy
The "House" has spoken...
check out my my 88 WS6 Trans Am
We are the seeds of legends,our true origins are unknown...WE SIMPLY ARE...
Old Sep 5, 2001 | 06:16 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
When I did my bypass, I couldn't stand the nipples sticking out, so I did some re-constructive surgery. Check it out: TB Bypass
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
[This message has been edited by GMTech (edited September 05, 2001).]
junior419
Apr 7, 2025 11:35 AM
djmarch
May 8, 2016 11:32 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Formula8r89
Sep 22, 2015 04:24 PM
Racerx974
Sep 19, 2015 10:16 AM
