Fuel pressure gauge?
Old Mar 21, 2008 | 10:59 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Hi, where would I find a fuel pressure gauge, that mounts on the rail of my 91 L98 T/A? I cant seem to find one anywhere, unless I have to modify something to work. I would rather get on that I can just screw on. Thanks.
Old Mar 21, 2008 | 11:47 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Re: Fuel pressure gauge?
like this one
Accell Fuel Pressure Gauge
Old Mar 22, 2008 | 12:10 AM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Well, yes, kind of.
1. It says for periodic inspection? Not made to be permanent mounted.
2. EXPENSIVE, But yes, if that is my only choice, then ya.
Thanks for the link, I dont really look at Jegs very often.
Are there any other ones?
Old Mar 22, 2008 | 06:16 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Summit has several, for way cheaper:
http://store.summitracing.com/egnsea...29&D=%2D127729
Old Mar 22, 2008 | 06:45 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
You might be better off mounting the FP gage away from the Fuel rail. Picture of my Autometer gage and mounting pod.
Old Mar 22, 2008 | 09:42 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
The one that comes with the black bracket is for permanent installation. The bracket is so that you can relocate the MAP sensor. I just put one on recently, so far so good.
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Kaweh
Aug 9, 2015 02:54 PM
