Can you port the part between the TB holes?
Old Sep 6, 2001 | 02:42 PM
ImportsRsloths's Avatar
Like the subject..... Can you port the bridge between the two holes so that it is like a square (i know there will be a triangle thing at the bottom that you can not port) I know a lot more air will be able to fill the plenum.... what are some benifits and stuff etc. thanks
Old Sep 6, 2001 | 03:10 PM
Bjase's Avatar
Car: 88 IROC
Adding an airfoil is supposed to be good for a few CFM. With so many aftermarket TBs available, it might not be worth the effort, unless you just want to be able to say you did it yourself.
88 IROC with cobbled together (not by me)drivetrain, 86 (?) TPI unit on an '83 305,CE subframe connectors, Edelbrock strut tower brace, polygraphite bushings all around...it handles like a dream, but man is it hard to push!!
Old Sep 6, 2001 | 03:53 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
This has just been covered about twice in the past few weeks, but i'll recap. Cutting out the divide between the TB bores in the plenum will probably serve no purpose. It *may* actually hurt more than it helps b/c the air leaving the TB will now have a sudden transition to the plenum, rather than a nice smooth taper that that area provides. Not that the turbulence created is necessarily significant enough to hurt flow (someone pointed out that the SR has only one big opening in it), it's just that why bother when the smoother entry can't hurt either. I'm sure you're not going to get any real power gains from the small increase in plenum volume.
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
LB9 A4 2.73 - 14.8 @ 93.1
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Sep 6, 2001 | 04:21 PM
breathment's Avatar
actualy the airfoil isn't supposed to help until your running 500 HP. just thought yall would like to know. and im not trying to sound smart or flame anyone, cause heck, i have one to
- David
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT
Old Sep 6, 2001 | 05:29 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
On my SuperRam there are two quite large throttle bores, I'd guess twin 58mm? I'm not sure if the new ones are the same but mine is not one big hole. Just sayin.
'88 RS (originally 2.8)
-350, .040 over, vette alum. L98s, stock tpi.
-305 injectors & chip
-TES headers & edelbrock cat back
-3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 356-13.7@101mph
on a 2.050 60 ft.
(Damn the 2.8!)
<img>http://www.geocities.com/gillowtex/outside12-small_engine_copy.jpg</img>
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
mx127
Aug 10, 2015 08:13 AM
1nastygta
Aug 8, 2015 07:38 PM
