good cam for tpi?
Old May 4, 2008 | 12:45 AM
  #51
thesargster4's Avatar
Car: 1986 WS6 TransAm
Engine: THREEFIDDY!
Re: good cam for tpi?
LT1 cam would work good. you can get those for cheap.
else keep it small as well, something around 212-214 intake duration, 218-220 exhaust
My LT1 cam runs great in my stock TPI L98. Just built it for my daily driver.. search ebay, got mine for $25 like new!
Old May 4, 2008 | 01:13 AM
  #52
85irocz355tpi's Avatar
Car: 85 IROC-Z
Engine: 355 TPI
Transmission: 700R4w/Shift Kit
Axle/Gears: B/W 9 Bolt-3.45
Well I'm gonna throw you guys for a loop here. I see you guys are talking about zz4's and lt1's and such. Here's what I got. I have an 87 and later 350 block(So I could use a roller cam.) Rebuilt 85tpi 305 heads with a set of Z28 springs. Dished pistons for the 305 heads.(9.1.1-9.5.1 compression). And drum roll please. A PBM roller cam. 214/224 duration. .470/.490 lift. I am running a hypertech thermomaster 305 chip. Stock converter. 3.42 gears. This has verry little lope and is good till around 5000-5500RPM's on my tpi motor. It is verry close if not slightly over 300HP on a stock tpi intake. I can beat stock LT1's all day long so i'm not off by much here. If you look up pbm you should be able to find it. I think my machine shop offers it for around 150-200 bux brand new. I like it and have been running it for 2 years with no problem. The springs I have are good to .500 lift so I will have to have some work done before I put some 1.6 rockers on it but I'm overall happy with this setup for now. I'm also running flowtech headers with true dual 2 1/4" exhaust with 40 series Flowmasters.
Old May 13, 2008 | 07:06 PM
  #53
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
http://store.summitracing.com/partde...4&autoview=sku
so this is the cam i am going to get with a higher stall anyone using this one
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro71633
Sep 1, 2015 10:24 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
drathaar907
Aug 6, 2015 04:20 PM
