Well, I've got a problem with my fuel pressure. I'll set it to around 46-48 psi, and then after a minute or so, it drops down to like 36. I put on a Crane AFPR when I rebuilt the motor, but the cheap bastard I am didn't replace the diaphragm. It looked to be okay, but it had 90K miles on it. Could this be causing it? I have a new fuel pump and filter too. Any help would be greatly appreciated. Thanks.
1984 Camaro Sport Coupe - Rebuilt 355 S/D TPI L98, Crane 2032 CompuCam, Crane adjustable fuel pressure regulator, MSD Blaster coil, custom burned PROM, stock TPI intake, Accel 24# injectors, gutted air box with K&N filters
F41 Suspension Package, 700R4 Tranny, TCI Breakaway torque converter, 3.27 Posi Rear
Hooker Shorty Headers, Catco High-Flow 3" Cat, Flowmaster 3" American Thunder Cat-Back
Best 1/4 Mile Run:
14.137 @ 94.57 MPH
1992 1LE B4C Police Camaro RS - 305 TPI 5-Speed
Best 1/4 Mile Run:
14.137 @ 94.57 MPH
pull the vacume hose of the fpr if fuel is present in hose replace diaphram you have a leak or else you may have a faulty check valve in your fuel pump
Nope, there's no fuel in the vacuum line. I just did the fuel pump a month ago. Any other ideas? Thanks.
[This message has been edited by CamaroX84 (edited September 07, 2001).]
