harmonic balancer pulley
Old Sep 7, 2001 | 03:05 AM
pontiacpete's Avatar
hi guys need help removing the pulley from the balancer the middle screw is impossible to remove the balancer keeps on turning as i try to unscrew the bolt any ideas?
Old Sep 7, 2001 | 08:23 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
do you have plugs in the engine? because if there are plugs in, it will make it harder for the motor to turn over.
is the serpentine belt still on the car? the added tension on everything that the belt gives will make it harder for the motor to turn over too.
do you have access to an impact wrench? that will take it off in a hurry. or, just try to get a sorcket on it and hit it softly with a mallet. the impact of that will sometimes break it free, without creating enough force to spin the balancer.
-brian
1991 Camaro RS - ultra blue metallic, t-tops
GMPP 350 HO crate engine - 454 TBI, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
1998 Pontiac Grand Prix GT - 2 door, black
Old Sep 7, 2001 | 11:43 PM
kane91z's Avatar
Car: 91 Z28
Engine: 5.7
use a cordless drill with a socket... It won't turn it at all...
91 z28 lb9 5 speed - hooker 1 5/8 headers - high flow cat- full 3 inch exhaust - home made ram air - tpis airfoil - dual chamber flowmaster - Stage 2 Jet Chip and 160 stat - 8 mm Msd plug wires - 55,000 v hypertech coil/rotor/distrib. cap - Mac. White face gauges - lots of sound system crap...
Old Sep 8, 2001 | 09:14 AM
JETHROIROC's Avatar
Leave the belt on and the plugs in, grasp the pulley with one hand to keep the engine from turning and turn the bolt with a 1/2" breaker bar in the other. You don't need any fancy tools, just muscle. Putting it back on to 70 ft-lb while holding the engine is the hard part by hand . Just did this last week.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
monte87cortez
Sep 26, 2015 08:10 PM
JSDaddy189
Sep 26, 2015 03:50 PM
