What roller rockers do you recommend?
Old Mar 24, 2008 | 06:22 PM
SDalt404's Avatar
Car: 1988 GTA
Transmission: 5 Speed
I am getting new valve stems seals put on and I want to replace the roller rockers and springs since they will be off anyways.
What springs and roller rockers do you recommend for a stock 5 spd 305?
Old Mar 24, 2008 | 11:42 PM
BadSS's Avatar
Re: What roller rockers do you recommend?
Comp 981s and heat treated stamped steel 1.6 rockers if you're not changing cams.
If you think you'll change cams any time soon,,, might want to go ahead and get the 941s and +.050 locks to set the springs at 1.75". Anything close to or over .500 lift would benefit from true roller rockers,,, not just the roller tips. The Proform roller rockers are decent for the money on moderate cams. For a little more,,,, in case you see yourself eventually going with a serious hydraulic roller or a pretty aggressive high lift solid roller,,, the Comp Pro Magnums would keep you from having to buy another set on down the road.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
TexasMaro
Sep 15, 2015 06:50 PM
