Is a AFPR really worth 60 bones?
Old Sep 8, 2001 | 04:06 PM
Ben_Jamin's Avatar
Just wanted to hear what you guys have to say before I spend money on one, I know that 60 doesn't sound like that much, but to some people it is.
Old Sep 8, 2001 | 04:22 PM
JETHROIROC's Avatar
It really all depends on what mods you presently have, and what mods you are planning to do in the future. On a stock TPI, I'd spend the money on intake and exhaust improvement before I thought about an AFPR. Tell us some more about your car and we'll be glad to give our $0.02.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Sep 8, 2001 | 06:00 PM
robert1's Avatar
Make your own AFPR. I used a 1/4", fine thread bolt. I had a nut brazed to the top of the housing. I adjust it just like the expensive ones. If needed, throw a little silcone glue on the threads if it leaks.
Old Sep 8, 2001 | 10:34 PM
Vader's Avatar
I'm probably just cheap, but considering what you get for $60-90 in an aftermarket AFPR, I don't feel it's worth it unless you don't have the means to convert your own. Considering the advertising philosophies of many performance automotive aftermarketers, they'll take the worst-case scenario to make the most aggressive power gain claims (so they can be just barely legal in their advertisements) and try to make everyone believe they'll get the same increase. If fact, most engines will run best at very close to stock settings. LT1 engines actually lose power when the fuel pressure is increased more than 2-3 PSI above the stock setting.
Then again, if I recall correctly, the VP of Sales and Marketing at Accel is Mr. Ben Dover, and he has relatives at some other aftermarket companies...
Later,
Vader
"Click - Click - BOOM!"
Adobe Acrobat Reader
Old Sep 9, 2001 | 07:30 AM
IROC&ROLL
Guest
Posts: n/a
If you just want to boost FP, and don't plan on making constant adjustments (I'm not sure who would), you can just open the FPR up and place washers between the top and the spring, thereby increasing spring pressure (and FP). Just expirement with the thickness or number of washers until you get the desired FP.
Old Sep 9, 2001 | 12:42 PM
90Iroc-Zee's Avatar
I have a Holley AFPR if you want to buy it off me for $40 bucks. I purchased it for $90. Email me if interested.
1990 G92 5spd LB9 - 3.42 80,000 miles
Accel Ignition/Wires (8.8mm), Advanced Timing, TB Bypass, Ported and Gasket Matched Plenum, Synthetic Motor Oil, 160 Thermo, TPIS Airfoil, K&N Air Filters, Centerforce I Pressure Plate and Clutch, Edelbrock TES Headers, Dual Cats, Edelbrock RPM Series Catback, Homemade Ram Air, Bosch +4 Platinum Plugs
14.4 @ 94mph w/2.0622 60ft (w/o headers and catback)
14.426 @ 96.19mph w/2.167 60ft(w/headers and catback)
Also newly modded w/o track times:
Holley AFPR, Underdrive Pulleys, KYB Shocks and Struts, Crane Ignition
Old Sep 9, 2001 | 02:28 PM
Ben_Jamin's Avatar
here are my mods: 3" flowmaster cat back, slp cold air w/k&n, slp intake runners, edelbrock 52mm TB, msd super hei kit with blaster 2 coil, this is on an 305 auto
Linson
Oct 24, 2025 02:00 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
Reid Fleming
Oct 10, 2015 09:56 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
