Engine temp gauge broke?
Old Sep 8, 2001 | 06:13 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
It doesn't work anymore. It goes up to 100* and thats it. Do you think its a sensor? If so which one and where is it? Any help would be great. Thanks.
Mods: ZZ4 engine w/stock TPI, adj, fuel pres. reg., MSD 8.5, HI6S ign. w/ PS-91 coil, K&N filter, TPI air foil, Hooker comp. shorties, American Thunder flows. 160* stat., TB bypass, 3"cowl, bat. relocate, AC delete, stock T-5 w/ 3.42 rear, ported plenum, 24# inj.
Old Sep 8, 2001 | 10:47 PM
Vader's Avatar
FB,
The sensor for the dash instrument is located in the left (driver's side) cylinder head. Check the resistance of the sensor and compare it to the table. If the resistance isn't correct at a given temperature, replace it.
As a hint, the temperature gauge needle should travel to full-scale when the engine is being cranked. If not, the problem is more likely in the dash instrument itself.
Later,
Vader
"Click - Click - BOOM!"
Adobe Acrobat Reader
Old Sep 9, 2001 | 05:10 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
I'll try it and see what happens. Thanks Vader- one day the force might be w/ me.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Jae992
Aug 27, 2015 09:07 AM
bamaboy0323
Aug 15, 2015 07:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
