Best Heads/Cam setup for SuperRam???
Old Sep 7, 2001 | 04:47 PM
CamaroX84's Avatar
Well, I'm replacing my cam, heads, and intake over the winter. I'm probably going to get the SuperRam. But what about heads and a cam? What combo works good? I know people have gotten into the 12s naturally aspirated on TPI before, and that's where I wanna be. Any help would be greatly appreciated. Thanks.
1984 Camaro Sport Coupe - Rebuilt 355 S/D TPI L98, Crane 2032 CompuCam, Crane adjustable fuel pressure regulator, MSD Blaster coil, custom burned PROM, stock TPI intake, Accel 24# injectors, gutted air box with K&N filters
F41 Suspension Package, 700R4 Tranny, TCI Breakaway torque converter, 3.27 Posi Rear
Hooker Shorty Headers, Catco High-Flow 3" Cat, Flowmaster 3" American Thunder Cat-Back
Best 1/4 Mile Run:
14.137 @ 94.57 MPH
1992 1LE B4C Police Camaro RS - 305 TPI 5-Speed
Old Sep 7, 2001 | 04:59 PM
ImportsRsloths's Avatar
From what Ive seen the best/ultimate TPI head is the AFR 210cc heads (alot have 190cc but the 210 is better but more $$$) for a cam id go with an LT4 hot cam or something like that.
Old Sep 7, 2001 | 07:43 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
CNC'd L98's or AFR 190's would be my choice if I had the cash. I would stay away from the 210's unless you have at least a 383.
92Z28
89GTA
Old Sep 9, 2001 | 08:24 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I got the AFR 190's and LPE 219 cam. I figured Lingenfelter could probably grind the best cam for his own intake. Someone posted some dyno figures a few weeks ago on different cams w/ the SR and the LPE 219 did the best, although the was one or two other cams that came close.
89 IROC-To see mods go to: http://www.geocities.com/buckeyeroc
Old Sep 9, 2001 | 10:56 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
AFR 220s are definitely too large for a 350 superram. Your port velocities will be far too low, not to mention possible intake/head mismatch.
I'm building an AFR190 LPE219 SuperRam motor right now; I'll give you my opinion on how it runs just as soon as I'm done
I've even seen recommendations to use the new 180cc heads from AFR for port elocity reasons.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
