hooking up wires and sensors....
Car: 1987 IROC-Z
ok, engine is in, manafold on up is on, exhaust is on, and im in the process of hooking things up.... and learning how to set the timing (since i forgot to mark it when i pulled the distributor) and ive run accross 2 connections that look the exact same.... one is for a sensor in the back, on the bottom, of the tpi plenum. now the two connections that look the same are 1) one goes into a wire that looks like it feeds through the firewall, after another conection, and the other feeds to my ignition coil. i just want to make sure before i take another step because once everything is hooked up, that connection under the plenum is a ***** to get at.
also, im not quite sure what fuel line goes tro whitch connection on the fuel rail... i know one feeds the engine, and one goes back to the gas tank, but whitch one goes how?
thanx
jon
[This message has been edited by sunbound (edited September 09, 2001).]
thanx
jon
