TPI manifold base
Old Sep 10, 2001 | 03:48 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
TPI manifold base
Do you guys know if anyone makes a TPI style intake (lower only) that can be ported out to a felpro 1206 intake gasket?
Old Sep 10, 2001 | 09:00 AM
87tpi420's Avatar
i wish i knew, i set my superram base onto my brodix heads and i had about 1/4 inch on the intake ports on the head showing. i allmost crapped myself. but i had it welded up and i ground it down inside. i know the miniram will fit, but thats not what you asked. im not sure about others
just my $.02
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
Old Sep 10, 2001 | 12:01 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Thanks. That's all I needed to know. I already knew about the MiniRam though. My decision is made.
Old Sep 10, 2001 | 10:54 PM
robert1's Avatar
The Edelbrock works ok. I use AFR 195cc, and that's what I did. There was plenty of room.
1992rs/ss
Jan 31, 2025 05:10 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
