code 33 and ses light on constantly
Old Sep 13, 2001 | 01:21 PM
Fastcamaro87's Avatar
i am getting a code 33 and a ses light constantly, it started doing this yesterday, i have an extra MAF sensor, that i am going to try putting on later.what could be causing this? i checked out the MAF on the car, and the wire is not broken,,
87 IROC-z 305 TPI 5spd 10-bolt 3.73 posi ,8.8 Accel wires , bosch platinum +4 plugs,MAF sensor screens removed, gutted air box, ram air, K&N air filters,TB coolant bypass ,polyurethane tranny and torque arm mounts, K&N oil filter,Mobil 1 synthetic oil 20w50, futura GLS super sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
Old Sep 13, 2001 | 02:23 PM
rezinn's Avatar
I've gotten the low voltage reading(code 34) from bad MAF connections, but I've never had the code 33. I would suspect the actual sensor is bad, or you could have a vacuum leak somewhere near the sensor. If the new MAF doesn't fix the problem, replace the relays and make sure all of the wiring is good.
Old Sep 13, 2001 | 02:40 PM
leirch's Avatar
Do a search on code 33.
eightsixseven
Dec 16, 2024 01:50 PM
chazman
Aug 28, 2018 03:25 PM
GouldyGTR
Aug 21, 2015 10:43 PM
Omega
Aug 10, 2015 12:46 PM
