help with slp runners &ported plenum/base
Old Sep 14, 2001 | 02:11 PM
89IROCZZ4's Avatar
I am thinking about getting these items on my zz4. Right now, all I have is a stock tpi setup. Apparently, it's choking the life out of the zz4's power potential. If I get the slp runners and port my base and plenum, along with doing a ramair setup and goto a 52mm tb, could I see 60 hp or more than what I have now? Will these items flow enough to warrant the aluminum l98 heads as the bottleneck? Can I get better heads, and if so, will I see improvement? I also got 3.73 gears, but have not installed them yet. On 2.73's and the stock tpi setup on a zz4, I have run a best 13.30. I want to see low/mid 12's. I do not want to go w/the superram or miniram setup because of the money involved. No NOS either. I just want my car to run this well n/a. Any help GREATLY appreciated!
Old Sep 14, 2001 | 03:29 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
I don't know about any hp figures but you will definately see a gain with the runners and a ported plenum and base.
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package , dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, 16" IROC rims and ASCD SS hood.
future mods:
completely done over suspension, black paint with flames,
T-56 almost ready to go in, TPI swap coming up
Wifes new car:
95Z28, AT, leather, T-tops bone stock for now.
future mods:
header to tailpipe replacement and a cold air intake. Then I am just going to leave it alone
Old Sep 14, 2001 | 04:27 PM
91-ZZ4-Z28's Avatar
Go for it, but you have to remember that TPI cars are big on TQ not HP so no you will not see 30hp but you will see 10-15HP and 30-40ft.lbs.
If you run 13.3 now than a 12 will be done with the gears and intake.
1991 Z28 ZZ4 with LPE superram base, SLP runners, LPE 58mm T-body,Random Technology ramair,TES headers,24#svo injectors,ZEX nitrous,Walbro 255lph f-pump,Accel AFPR,Random Technology catback,!cats,and mutch more.
Old Sep 14, 2001 | 05:57 PM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
Wow! you run a 13.3 on a zz4 with the stock TPI setup?
I was thinking of picking up a ZZ4 at some point, but i figured i would need an entire new intake setup. a 13.3 with the stock TPI doesn't sound to bad to me. Please post your times after you swap the TB and port the plenum and base+runners!
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
Doesn't know enough about cars.
AIM: jesusathome
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
no green
Jan 9, 2016 09:22 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
