Free Mods?
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
Free Mods?
Are there any free mods I can do on my '88 GTA? 350 / auto
'89 Flame Red Metallic Trans Am GTA
Car: 88 T/A
Just do a search entitled "free mods" and you'll discover all kinds of things you can do.
88 Trans Am 305 Auto Red/Silver, MSD coil,wires, ported plenum, gutted airbox, TB bypass, comp cams 08-408-8, everything else stock
A couple of free mods are: Throttle Body Coolent Bypass, which will make the air going in cooler. You can also make a cold air induction Fairly cheap, just go to Ace Hardware and run a tube from your Mass Air Flow sensor and attach a cone air filter. The stock air box is pretty restrictive.
I have one question off the topic how do you gat it to say "'89 Flame Red Metallic Trans Am GTA" (for Example) under your posts?
Engine: 5.7L L98
I had to update my sig. The '89 is the one I was going to buy before finding out it wasn't a GTA.
Go to the Profile link at the top right of the page. You can set your signature in there.
'88 Gunmetal Grey Trans Am GTA
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
Basic "free mods" might be:
-cold air induction.
-160 deg stat and fan sw.
-TB coolant bypass.
-MAT relocation.
-cut-back spark plugs.
-advance timing.
-AFPR.
-port plenum & upper runners.
-gut the MAF.
-K&N air filter.
A lot of these are in the Tech Articles section; some on my site.
1986 IROCZ-28 Site
Best Times:
60'=1.92sec, 1/4mi=14.42sec @93.99mph in 65deg temp
[This message has been edited by Jim 86 IROC (edited September 16, 2001).]
-TB coolant bypass.
-MAT relocation.
-advance timing.
-AFPR.
-gut the MAF.
-K&N air filter.
1986 IROCZ-28 Site
Best Times:
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
