Finally going with the #24's
Old Sep 3, 2001 | 07:18 PM
LeftTurn1LE's Avatar
Okay guys. My car has been running like crap since its been back on the road because of bad injectors. A while back I bought a set from Accel which were 24lb. I haven't installed them because I have a SD system and I am going to get a chip done by Ed at FastChips. I'm planning on gutting the air box and getting some high flow air filters to go with the extra fuel. Any other suggestions that I should do during this short project? I will be tight on money so nothing outrageous. I just want it to run smoothly after I'm done. It should be fine to run off the stock fuel pump with this setup right?
91 Z28 1LE 5.7 automatic
SLP 1 3/4 headers, Random Technology cats, Borla exhaust, Accel 8.8 wires, Hotchkis STB, Pirelli P7000 Super Sports P 245/50ZR 16
More to come...
Old Sep 3, 2001 | 07:27 PM
Also, my car runs much hotter after putting on headers. In the city it gets well over 220*. Should I go with a colder thermostat since I'm getting a chip made anyway? I'm thinking maybe a 180* stat. It runs at normal temp while cruising. I think 160* might be too cold.
More to come...
Old Sep 5, 2001 | 12:47 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Go with a 170* thermostat. The only place to get them other than TPIS is the dealer (AC Delco). Look in the Tech Article section of this site under the cooling fan topic. It lists the part number in there. If you call and ask the dealer for it they won't know, its not in the catalog. But if you tell them the number it will show up. Why? I couldn't tell you. But according to most TPI knowledgable people, 170* is the temp you should be running with.
'91 GTA
350 TPI
700R4 from Pro-built
T-Tops.
Just a few mods, if you want to find out just line up next to me at a stoplight!
Wife:2000 Grand Prix GTP
Old Sep 6, 2001 | 09:25 PM
PonyKillerZ's Avatar
Im runnin a 160 in my moded 355...runs fine...may heat up a bit on the e-way. but not over even stock temp.
I to am thinking about 24#injectors...will it make in diff in daily driving and the 1/4 mile over stock?
Old Sep 6, 2001 | 09:37 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
I think those injectors are going to be a little big unless you have some future plans-wait thats a stupid question cause we all have future plans for more power.
You will have to run lower pressure to not run rich.
'88 RS (originally 2.8)
-350, .040 over, vette alum. L98s, stock tpi.
-305 injectors & chip
-TES headers & edelbrock cat back
-3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 356-13.7@101mph
on a 2.050 60 ft.
(Damn the 2.8!)
<img>http://www.geocities.com/gillowtex/outside12-small_engine_copy.jpg</img>
Old Sep 17, 2001 | 04:46 PM
thanks...
also
will an upgraded ignition...like MSD help with it runnin rich?
thanks
Old Sep 17, 2001 | 07:42 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
NAPA also stocks a 170deg thermostat. Also, try drilling 4 very small holes around the base of the thermostat, this keeps a hot pocket from developing around the thermostat (at least thats what I read somewhere, supposed to help). Don't forget a new fan switch to turn the fans on earlier. I have SVO #24 injectors in my ZZ4TPI. I run 35 to 38 lbs of pressure. My BL runs a steady 108 (computer pulling fuel). A blip of the throttle returns it to 128 (perfect).
Thats with a stock L98 chip reprogrammed for #24 injectors and with my S&P ZZ4TPI chip.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Rocket-Doc
Nov 14, 2015 02:08 PM
Antips16
Oct 30, 2015 06:42 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
