Vette prom
Old Sep 18, 2001 | 07:49 PM
nc-iroc's Avatar
Car: 1989 Iroc-z
Engine: 1998 L31 350
Transmission: 700 R4
Vette prom
Can I use an 89 vette prom in my 89 iroc? I wouldn't think there was much of a difference? Thanks
1989 IROC-Z Original 350 was swapped for a 305! Now I have a take-out 350 4-bolt main Vortec truck motor, ready to set things right
Old Sep 18, 2001 | 07:57 PM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
The only possible issue might be timing, since the '89 Vette has the #113 Al heads that run a little looler than the iron. If you want a killer, port a set of these heads and plumb in an external EGR tube like the Vette uses.
1986 IROCZ-28 Site
Best Times:
60'=1.92sec, 1/4mi=14.42sec @93.99mph in 65deg temp
Old Sep 18, 2001 | 08:02 PM
nc-iroc's Avatar
Car: 1989 Iroc-z
I didn't think there was a lot too swapping the chips. I just figured, I could use the factory chip as a guinea pig when I started burning my own. Thanks a lot for your help.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
FormulasOnly
Jul 23, 2018 08:47 AM
dusterbd
Sep 29, 2015 08:40 AM
Winchester1094
Sep 15, 2015 09:48 AM
