MAF sensor changeout
Old Sep 19, 2001 | 01:50 AM
aribob's Avatar
I have a 41 chevy conv streetrod with a 1986 Z28 TPI in it. Due to the very long MAF sensor, my air ckleaner rests on teh back of teh radiator- VERT hot intake air. Anyone know if I can delete, modify, or replace the MAF sensor to solove this problem? have heard that to do so requires a complete electronics change- $$$
Thx for any help!
Bob Sutton
Old Sep 19, 2001 | 02:14 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
You can switch to a Speed Density setup.
You'll need a new ECM+Prom, Knock sensor, Map sensor, and re-wire a couple of things.
Here is the website I am getting my info on my swap.
http://www.cis.udel.edu/~davis/z28/ecm_swap_730/
I already have my ECM, installed new knock sensor, waiting on the V8 Memcal prom from the dealer, and was about to attemp to re-wire the maf harness to the speed density computer.
Old Sep 19, 2001 | 02:07 PM
aribob's Avatar
First, thx a bunch for teh reply!
I am almost sure that mine is an 86 TPI, so it would be different than your 85- yes? I AM sure that it has a very large 3" diamter MAF sensor, and that is what I am trying to get rid of. Did yours have that as well?
<font face="Verdana, Arial" size="2">Originally posted by Zepher:
</font>
Old Sep 19, 2001 | 04:35 PM
Zepher's Avatar
The MAF setup I had was an 87, and it did have that large MASS Air flow sensor.
I am switching to Speed density becuase of that. Makes it hard to make a nice dual inlet cold air intake setup, there is no space for the tubing when using the MAF.
The website that attached earlier is not mine. I am using that site as a reference for doing my swap.
[This message has been edited by Zepher (edited September 19, 2001).]
BumpaD82
Feb 26, 2016 02:57 PM
sleprock
Oct 1, 2015 09:39 AM
Racerx974
Sep 19, 2015 10:16 AM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
earlpote
Sep 12, 2015 11:55 AM
