14, 42, & 45 codes. I need help!! :(
Old Apr 5, 2008 | 12:24 AM
SatisTraction's Avatar
it is a 92 TPI and it started to run like crap. after some research on here i swapped the ignition module under the distributor cap. on the 1st ride i got the same codes again.
I do not have a wiring diagram but is there a common wire that would cause all three codes?
the 42 code comes in as soon as i start the engine and the other two after about a minute or so of driving.
I am lost at this point so any help or suggestions would be great.
what actually triggers the 42 code? it is low fuel pressure but there is no pressure transducer???
thanks
chris
Falcon50
Aug 22, 2020 03:26 PM
bbsr72
Apr 2, 2016 09:12 AM
eustodp
Sep 20, 2015 05:09 PM
64Chief
Sep 12, 2015 08:05 AM
pacoelrapido
Sep 11, 2015 02:41 PM
