Need a part for my 1986 engine!!!!
Old Sep 20, 2001 | 10:27 AM
carnby17's Avatar
I have fully changed out the 1988 camaro(which had been flooded) with all the parts I had from my 1986 camaro that had the tuned port injection. I need a part that is called a silencer GM# 14082490(discontinued). Please Please help I need this last part so I can finish my car. I have the hose blocked off now thinking it is not necessary but the pump that is located right next to this part doesn't have anywhere to pump anti-freeze so it starts blowing anti-freeze out the back of the pump. The part looks like a coke can that has a whole in the center of it and has a tube coming to the top of it. It is located in the bottom left of the engine and is painted black. Please help!!!
[This message has been edited by carnby17 (edited September 20, 2001).]
Old Sep 20, 2001 | 10:50 AM
Desert86Roc's Avatar
Dude..you have problems. Nowhere does any AIR system connect to any part of the COOLING system. If you are truly working on the air system (which supplies air to your exhaust manifolds and cats), then you can use your old parts.
If you are working on the cooling system...the 86 did not have a heater bypass valve, and in stock configuration, routes the coolant from the intake into the TB, from the TB to the heater core, from the heater core to the radiator. No special devices needed.
Mike Metzler (Desert86Roc)[*] Check Out:SpeedWorldMotorplex.com[*] Check Out:Chevrolet F-Body Online Part & Illustration Manual[*] My 86 IROC 305 TPI Page (406 build in progress)
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.362 @ 88.238 mph (uncorrected, headers, no NOS)
Steven 86IROC-Z
Mar 28, 2026 06:42 PM
italiano67
Dec 11, 2016 09:21 AM
Caspar
Jun 19, 2016 11:19 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
1nastygta
Aug 8, 2015 07:38 PM
