TPI Converting mass to map
Old Apr 5, 2008 | 07:01 PM
4.3LMan's Avatar
Car: 91 GMC Jimmy 2DR
Engine: 4.3L now soon TPI V8
Axle/Gears: not sure yet
Hello everybody,
I own a 91 GMC JIMMY that I'm pulling the 4.3L out and putting in a TPI V8. The TPI unit I have uses a Mass Air Flow Sensor and I would like to convert it to use a Mao sensor. Can I just tap the hole on the plenum where it should be. This unit also has the cold start injector. I don't have the harness or computer yet. I plan on getting the computer and harness from Painless Performance. Besides getting new stuff what can I do?
Old Apr 5, 2008 | 07:35 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: TPI Converting mass to map
You can just not hook up the cold start injector. I've done that a couple times, or find the right size freeze plug for the injector hole, and silver solder up the end of the pipe just out of fitting.
You can tee off one of the other fittings if engine is together, but try to stay away from the map supply.
Old Apr 6, 2008 | 01:47 PM
4.3LMan's Avatar
What do you mean stay away from the map supply.
Old Apr 6, 2008 | 02:23 PM
NowTheBadNews's Avatar
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Just use your V-6 TBI harness to run the TPI system
Old Apr 6, 2008 | 02:44 PM
4.3LMan's Avatar
My Truck wiring is gone, bought the truck for 35$ with title and a good body.
No harness in truck.
Old Apr 6, 2008 | 06:08 PM
scuzz's Avatar
Engine: LB9
Axle/Gears: 3.55
I've always been told that you should run full vacuum to the map sensor, and not split it off.
Caspar
Jun 19, 2016 11:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
