didnt spin bearings, why knocking??
Old Apr 5, 2008 | 07:30 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Was dead on positive thinking we had spun a rod bearing pretty bad. Pulled the motor, got it on the stand, pulled the pan, pulled all caps off. Didn't see any spun rod or main bearings, only one main bearing was slightly scored. There were metal shavings in the pan though. This engine was knocking loud as a mother****er too, it definetly sounded like a rod knock. I checked the tranny bolts, and the flywheel isn't cracked either, and the bolts were damn tight. Me and my neighbor are stumped.
Edit- the motor was rebuilt 500 miles ago by the previous owner, and its bored 30 over
Old Apr 5, 2008 | 08:08 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: didnt spin bearings, why knocking??
did the noise quit when it warmed up i.e. hellashish piston slap?
Old Apr 6, 2008 | 09:46 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
pull heads look for lost bolt?
Check wrist pins.
Front damper keyway. I had one that sounded like a rod, but the damper keyway was badly worn. crank was okay. new damper and key all was well.
I know plasti gauge is not recommended on this board, but it might lead you to something that is way out of whack.
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
gord327
Oct 3, 2015 01:25 PM
gord327
Sep 29, 2015 10:18 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
