oiling problem,need help!!
Old Apr 5, 2008 | 07:32 PM
fastscooter's Avatar
I've got a 383 that does not get oil to the driver side rocker arms.I only ran the motor for a min or so,and pulled the valve covers off just to look.The passenger side seems fine,but I haven't hooked my oil pressure gauge up yet,so I don't know what the actual pressure is.
Old Apr 6, 2008 | 09:05 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: oiling problem,need help!!
take the valve covers off and run it for about 10-20 min after checking the oil preasure
while the engine is running get a oil squirt can and hit the non oiling rockers from time to time
after 10 mins the rockers should get oil
if not take the pushrods out and soak them in gas and blow out with compressed air
Old Apr 6, 2008 | 07:14 PM
jamon8 thanks for your help,but I got it worked out earlier today.I just didn't let it run long enough.
Street Lethal
Apr 30, 2019 12:14 PM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
