Crossfire to TPI
Old Apr 6, 2008 | 03:36 AM
emi_16's Avatar
Car: 1983 Z28 Camaro
Engine: Crossfire Injection 305 V8
Axle/Gears: 2.8??? stock fer sure
Crossfire to TPI
First Of All i have a 83 CFI Camaro
has about 400,000 miles on the body
80,000 on engine
ha
Well i dont like the CFI system..
It runs very nicely VERY nice torque and best of all MPG
but Ive been wanting to get rid of it. I dont want Carb. or X Ram
But i want TPI!
Can I use short block?(bottom end)
Can I use stock heads?
Can I use OEM ECM
Can I use with 700r4 not the E version
just
basically what do i need?
i asked on the CF forums but nobody is ever on that one so i wanna see here.
ANd also
I want a way to keep my Tranny in OD
so it can go
1-2-3-4 with no downshift
Old Apr 6, 2008 | 04:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I think the TPI forum would be a better place for this than the Carburetor forum.
Old Apr 7, 2008 | 07:48 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Re: Crossfire to TPI
Can I use OEM ECM
In order:
Yes, possibly yes, probably no (especially for a newbie), yes.
GM changed the angle of intake manifold bolts circa 1987+, so if you use an older TPI intake manifold then it should be a bolt on. Otherwise, for an 87+ manifold, you would need to use a round file and open up the bolt holes in the TPI intake. Do a search and you will find MANY posts on it.
The OEM ECM you have is a circa 83-84 TBI ECM.... so it's not designed to fire 8 injectors of the TPI. It might be theoretically possible (by a very experience DIYer) but for you, the answer is no. You need a newer TPI-specific ECM.
TPI will run a lot like CFI as far as torque and mpg, because CFI is the TBI version of the TPI.... it lacks only port injection. Otherwise it is also an equal-length-tuned intake manifold system, and it was designed by the same people at GM that did TPI. So you may feel a slight increase in torque at a slightly lower engine rpm, and the TPI should allow more power because the runners have a slightly larger cross sectional area, but it won't be significantly different than what you have now and the above list (to mod from CFI to TPI) will be a lot of work, especially for a novice. HTH.
stalkier
Dec 6, 2015 11:25 PM
3tas4me
Sep 4, 2015 01:45 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
3rdgenparts
Aug 6, 2015 09:03 AM
