Mass air inter-changability
Old Apr 7, 2008 | 02:56 PM
tnmedic's Avatar
I am looking on ebay for a maf. There are a lot of different years listed from 86 to 89, camaro to firebird. Does the year or model car matter just for the MAF? Any information would be appreciated. Thanks Medic
Old Apr 8, 2008 | 09:58 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: Mass air inter-changability
Any gm 305/350 tpi 86-89 will work.
Maf Part Numbers
213-161
0280213002
0280213004
0280213009
10055877
14081243
14094712
Micro tech 49-1018A
Circuit Board Type
GRANATELLI
350100
CB type
Old May 28, 2008 | 11:18 AM
CobraEatr's Avatar
PLEASE forgive me for hijacking this thread, but I have an '85 TPI setup and I'm using MAF P/N 0280213002. I was wondering if I can use another year ('86-'89) MAF on my '85. I don't think that I can because I found out that the '85 is the only year to have a MAFS (P/N 0280215001) module which is used with the above mentioned MAF. If I could use another year's MAF then I can pick one up locally. If not then I need to order one.
Old May 28, 2008 | 02:51 PM
MY87T/A's Avatar
Car: 85 IROC "SYNASTR-Z"
Engine: 355 SBC
Transmission: 700-r4
Axle/Gears: 3:73 disc brake
I dont know if this is good for my computer. But i have an 84 305 TPI MAF on my 87 350 tpi.
Old May 28, 2008 | 03:15 PM
CobraEatr's Avatar
I'm pretty sure that '85 was the first year for TPI. Are you sure it's an '84 MAF?
http://www.geocities.com/f_body28to3...toryof_fi.html
Old May 28, 2008 | 03:37 PM
Guest
Guest
Posts: n/a
If you have an 85 you're stuck with using an 85 MAF sensor.
Old May 28, 2008 | 03:39 PM
CobraEatr's Avatar
That's what I was afraid of. Thank you.
Old May 28, 2008 | 03:44 PM
MY87T/A's Avatar
Engine: 355 SBC
well i am pretty sure it was an 84 tpi motor. the car was an 84 so maybe someone switched it.
Old May 28, 2008 | 03:48 PM
CobraEatr's Avatar
It sounds like someone upgraded the '84 carb setup to TPI. Check the part number on your MAF and post it here. Then we can tell the range for what year TPI the setup is from. PRAY that you don't have an '85 TPI setup.....PRAY.
Old May 28, 2008 | 07:07 PM
MY87T/A's Avatar
Engine: 355 SBC
why? is it a bad one. And its bosch 0 280 213 002 14 081 243 made in germany. And it say edcba on the plug part.
here is a link to a picture of it. it is all the way at the bottom. https://www.thirdgen.org/forums/tpi/...-question.html
Old May 29, 2008 | 07:57 AM
CobraEatr's Avatar
That's the same part number that I have. I have an '85 TPI setup. The '85s were the first year that TPI was introduced by GM. They use a unique MAF and a MAF control module (called MAFS) which piggybacks the ECM. From what I've read on the internet (someone correct me if I'm wrong) an '85 MAF is not interchangeable with an '86-'89 MAF. This is because the '86-'89 MAF sends a voltage to the ECM while the '85 MAF sends a frequency (?). Also, I've read that the '85 TPI setup is 'unreliable' (not sure why) and not as efficient as the '86-'89 TPI setup. This is understandable as it was the first year for TPI. And as we all know, the first year for anything new normally has its share of bugs.
To confirm that you have an '85 TPI setup, look at your ECM and see if there is a module close to it (P/N 0280215001). If so then you're stuck just like I am...........with GM's very first TPI setup.
Old May 29, 2008 | 10:50 AM
MY87T/A's Avatar
Engine: 355 SBC
No the whole setup in the car is my 87's original. The only thing i took from the 84 was the intake system. The guy took the motor and trans and we just crushed the car. It was rotted out fully. So your saying that i better take that 85 off and put the bad 87 one on it? Cause you said it isn't interchangeable
Old May 29, 2008 | 11:17 AM
CobraEatr's Avatar
I'm not a TPI guru, so check with some of the 'elders' around here, but I'd say that if you're having a problem then that certainly might be it. The '85 MAF doesn't send the same voltage to the ECM that the '86-'89s do. So if I were you I would disconnect the MAF and see how it runs (your ECM will use pre-programmed voltages). If it runs better than the MAF is your problem. If the problem still persists then your MAF probably isn't the problem.
Old May 29, 2008 | 11:27 AM
MY87T/A's Avatar
Engine: 355 SBC
well i was running a straight pipe intake with no maf all the way on interstate to my house bout 20 miles. And it ran way better had more torquey ness to it. And it also idled smooth as glass.
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
