TPIS Bosch in-tank pump...850 HP???!!
Old Apr 7, 2008 | 09:18 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Here is my dilemma. I have a 406 minirammed motor with Holley 255lph in tank pump using stock lines and I am running out of fuel pressure at 6300 rpms.
I already ordered the Racetronix hotwire kit and am looking for a bigger in tank pump. I stumbled across this pump that TPIS sells. Its a Bosch in tank and claims to support 850 HP. Anyone ever look into this?
I am wondering if it feeds a bulkhead fitting in the sending unit to a -8AN line and uses the stock 3/8" line as a return.
http://www.tpis.com/index.php?module...ory=Fuel+Pumps
Old Apr 7, 2008 | 09:24 PM
stevo the torpe's Avatar
Car: 91 maro
Axle/Gears: 373 locker
Re: TPIS Bosch in-tank pump...850 HP???!!
thats one bad *** pump
Old Apr 7, 2008 | 09:45 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
do you have experience with it? Does it really support that kind of HP?
I was also thinking about a double Walbro 340 setup sort of like the Turbo Buick crowd does. They run higher fuel pressures and cars on stock lines into the low 10's on these.
http://members.aol.com/bigturbo1/fuel1.html
look about half way down the page.
Old Apr 8, 2008 | 11:23 AM
Guest
Guest
Posts: n/a
That doesnt look any different than the Bosch pump I have, that I paid much less than $350 for. I wasnt aware it was intank only, because it had a 3/8" inlet and I had it mounted inline. I wonder if that pump really is any different... kind of doubt it. I'm not using it anymore, I might be able to read the part number off of it if I can get the hose off we used to try and insulate it... its noisy. I dont know about 850HP, but at 450 it was keeping up fine.
Here's another view of what is likely the same pump
http://www.accel-dfi.com/ProductDeta...minselection=0
At one time both TPIS and Accel were selling the same pump, and both are a slightly modified Bosch unit because the outlet fitting is an oddball size. Look up one for a early-mid 80's Porsche 928, thats what it is. Rockauto sells a Delphi version of it for $208.
New2Chevy
Oct 4, 2015 11:27 PM
bamaboy0323
Sep 3, 2015 06:07 AM
NBrehm
Aug 25, 2015 11:49 PM
Firechicken86
Aug 12, 2015 10:07 PM
Sanjay
Aug 12, 2015 03:41 PM
