How did you plumb your inline fuel pump?
Old Sep 22, 2001 | 08:04 PM
Chris Sartori's Avatar
Hi All!
Just recieved my inline elctric fuel pump from Summit and wanted to know how you plumbed this beast inline? There is a high pressure rubber line that joins the sender(pump)to the chassis fuel lines. I was going to install between these but the brass fittings I had were either pipe thread or standard threads and neither would seal? Were do I get brass fittings that has the O-ring type threaded fittings like on the car??
Any different way of plumbing this in? I really appreciate any thoughts or help!
Thanks a bunch!
kyrenegade
Old Sep 22, 2001 | 09:41 PM
87tpi420's Avatar
you might try www.aeroquip.com i am not sure of the size but aero part #is fcm2608 for the m16 x 1.5 and the fcm2609 is m18 x 1.5
they are listed "for use with saginaw power steering fittings and also gm fuel injection conversion for metric o-ring style porting"
also the phone # is (419)8915100
i have the full catalog of aeroquip performance products and thats what i found.
hope that helps
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake hooker long tube headers mufflex 4"exhaust accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
Old Sep 22, 2001 | 10:09 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
You are looking for what they call a Sagniaw fitting.
I only found Accel that offered an adapter to convert these to AN fittings, or had a 6" length of fuel line with these ends.
I also heard from another person that he found the same 6" line and end at a local auto parts store.
Make sure to use HIGH pressure fuel line for any rubber connections (and the special hose clamps).
Mark.
Old Sep 24, 2001 | 08:39 PM
cfabe's Avatar
For the saginaw fittings I used the accel saginaw to AN fittings, and then some more fittings to turn it into NPT pipe thread, and then some more fittings to turn it into hose barb. Like 7 fittings in all, pretty insane. Oh, and you dont need high pressure hose for the return line, only the supply side. No restriction on the return line so theres little if any pressure. This saves you some bucks considering the high pressure line is like $4-$5 a foot IIRC.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Dialed_In
Aug 20, 2015 01:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
