AFR heads and LT4 Hot Cam
Old Sep 26, 2001 | 11:33 AM
sbrice18fan's Avatar
Car: 1990 Chevrolet Camaro RS
I am looking at bying a set of AFR 190 heads, they come completewith Hydrolic valve spprings, 120 lbs. on seat, .550" maximum lift. My question is if I buy the LT4 hot cam do I need to buy the LT4 springs or can I use the springs on the AFR heads. I just want everything to match up and I don't want to spend money that I don't need too. Is anybody running this combination ? Thanks for the help.
1990 RS Camaro 305 TBI, 700R4 Tranny, 3" cat back system with flowmaster muffler, Edelbrock strut tower brace, rear panhard bar, and torque arm, Spohn subframe conectors and lower control arms, all polyurithene bushing under the car, KYB gas adjust shocks and struts, March underdrive pully system, Taylor 8mm plug wires, Accel super coil, K&N air filter, Hypertech chip, GM Aluminum driveshaft, 3.42 Zexel-Torsen Rear end with superior 28 spline alloy axles, and Summit aluminum rear end girdle, Killer sound system, Many new mods to come (swap to 350 comming soon)
Old Sep 26, 2001 | 02:57 PM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
If I remember correctly...the lift on the LT4 cam (you have to use 1.6 rockers) is like .525"......and the max lift of the AFR Heads is like .550 or something like that. So yes it will work without new springs.
Jake_92RS
Jan 28, 2020 10:37 PM
evilstuie
Jan 9, 2020 08:29 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
anesthes
Aug 8, 2015 09:37 PM
