What is the minimum requirements to use the mini-ram?
Old Oct 29, 2000 | 09:23 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
What is the smallest cam you can run with the mini ram?
This will then point to a looser convertor I suppose.
Are edelbrock heads suitable or is a head with 190cc intakes or better required?
How does the cost of a mini ram compare to that of the superram base and the large tube runners?
... just starting my winter/christmas list.
Mark.
Old Oct 30, 2000 | 09:31 AM
Bill91Z
Guest
Posts: n/a
MArk, I have a friend (who's name is also Mark) that runs the miniram on a stock l98 formula. Can't get much smaller of a cam and TC than that? He has experienced great results just from swapping the intake.
Old Oct 30, 2000 | 10:06 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Mark, with the MiniRam, you also have to get a fuel rail kit (though a few have fabricated their own) and the chip (a few have found others to burn a PROM for them too).
Currently, a few are investigating the Ram Jet setup. You will have to get "Fast Burn" heads to work with the RamJet intake, but you were looking at heads anyways (as most of us are too).
Scope out the "RamJet" thread in the Scoggin-Dickie Parts Center for more info on the Ram Jet intake.
Old Sep 26, 2001 | 07:42 AM
Mike89GTA's Avatar
What's a good place to buy a used mimiram?
Old Sep 27, 2001 | 06:54 AM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
Hey Mark I think I'm the one Bill is referring to.I put the Miniram on only with future plans of a total package,my car would probably perform better right now with a stock runner type setup,but I will not buy parts twice and I couldn't buy the Miniram,heads,headers,throttle body,torque conv,gears,cam,and so on all at once
89 FORMULA 350,WS6 SUSPENSION,HOTCHKIS STB,KONI REDS,WONDERBAR,SLP REAR CONTROL ARMS/PANHARD,POLY BUSHINGS,FRESH 355 MOTOR,TCI 12" STREETFIGHTER,TRANSGO SHIFT KIT,3.70 GEARS,FLOWMASTER EXHAUAST,SLP 1 3/4 HEADERS,NO CATS,58 MM BBK,MINIRAM INTAKE,COLD AIR,ALL FREE MODS
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
ZZ3Astro
Aug 13, 2019 12:57 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
