Possibly bad cats?
Old Apr 12, 2008 | 05:52 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Possibly bad cats?
So my car has been acting up recently. From time to time my cats will start knocking and rattling, and when that happens, my car would start running a bit poorly. It would seem to have still good low end, but as the car gets going higher in the revs, it seems to have more problems. Then occasionally the cats would stop rattling and the car would seem to run ok. Could bad cats be the cause of my problems. I just checked all my wires, which are new about 2k miles from when my engine war rebuilt, so I don't think that it is a tune up issue, and the car does not have any codes stored. Could clogged cats cause my car to run this poorly and make it idle a bit rough?
The cats are welded on there, and I don't think that I would have a way of knowing what is going on in there without cutting them off.
Any suggestions would be greatly appreciated.
Old Apr 12, 2008 | 06:31 PM
Shamble's Avatar
Car: IROCZ
Engine: LB9
Axle/Gears: posi
Re: Possibly bad cats?
Clog cats is a possibility. If you are unsure just replace the cat. Muffler shops can cut and install them for you. I would do a tuneup again even though the engine was rebuilt. knocking and rattling isn't something to push aside. running clean is mean
Old Apr 15, 2008 | 04:27 PM
Saculia's Avatar
Engine: 305TPI
So it did happen to be one bad catalytic converter. The other looked fine, but I think I would replace it in the near future since it could be on its way out.
The bat cat was the one on the left side. It looked as if someone had taken a stick and pushed the honey combs into the exhaust pipe. After the replacing that cat, my car runs so much better. It revs a lot easier, and runs like a raped ape.
Old Apr 15, 2008 | 05:44 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
i had that 6 months back and now it did it again. Looked exactly the same inside
Old Apr 15, 2008 | 05:53 PM
Saculia's Avatar
Engine: 305TPI
Make sure that you don't have any spark plugs that are missing, and also that your O2 sensors are functioning properly. A miss will make your cats go bad in a heart beat.
Also, when you replace your catalytic converter, replace it with a good quality one. I have found that when I spend 50 bucks on a cat, I get what I pay for - garbage.
chazman
Aug 28, 2018 03:25 PM
formula_novice
Sep 5, 2015 03:58 AM
nuggie
Aug 25, 2015 01:27 PM
Out-Cast
Aug 22, 2015 07:49 PM
chazman
Aug 22, 2015 02:01 PM
