AFR Heat Riser?
Old Sep 26, 2001 | 11:48 PM
JR4444's Avatar
AFR Heat Riser?
I am getting some heads from my friend and I wanted to know what a heat riser is? From what I have gathered the heads dont have them and I think I need them to pass the polution tests here in Arizona. Thanks
Old Sep 27, 2001 | 01:24 PM
robert1's Avatar
There is an old "heat riser" valve. It shut down the exhaust from one side of the exhaust, and recirculated it through the intake manifold. This heated the intake charge and warmed the air for better fuel atomization. If you are runnung a TPI, this is not needed for anything. You can block it off (in the heads), unless you need it for the EGR valve. GM actually sells a spacer to remove the "heat riser valve" from the exhaust altogether.
Old Sep 27, 2001 | 01:50 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
The emissions-legal heads have "heat riser" passages drilled into them - which means there's a hole on the intake side that intersects with the center exhaust passages. This is used for EGR, an emissions-control device.
If the heads don't have the heat riser hole you may be able to drill it, or use an intake base that accepts Corvette-style EGR that's fed from the exhaust manifolds.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ULTM8Z
Oct 2, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
